Engine ID
Old May 23, 2002 | 03:16 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
Engine ID
I am in the process if buying a 85 z28 (i hope it's a z28) 5 speed. the guy told me it is a 350 but not the original how would i find out what size the motor is in there before i find out it's not a 350 and more like a 305. thanks.
Old May 23, 2002 | 03:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Your best bet would be to get the casting number off of the block. It's located on the upper driver's side of the bell housing mount. Check that against www.mortec.com, and you should have a fairly good idea what it is.
Old May 23, 2002 | 05:13 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
thanks man im gonna go check for the munbers later on.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
