Cam Identification
Subscribe
May 25, 2002 | 09:13 AM
I need to Identify this camshaft was put into my engine a chevy 283 in 1992 the number are: 911753
There are some other numbers however I think this is a production code C052) C-?/0-year/52-julian date of year/ could be wrong but im just guessing.
Reply 0
May 29, 2002 | 11:46 AM
Finally got the info that I really needed! Called CRANE and they found it the database from Blueracer:
Crane Camshaft Specification Card
Part Number: 911753
Grind Number:
Engine Ident: 1957-1987 CHEVROLET V-8 262 THRU 400 CU.IN.
VALVE SETTING: INTAKE .000 EXHAUST .000 ----> HOT
LIFT: INTAKE @CAM 000 @VALVE 480 ROCKER ARM RATIO
EXHAUST @CAM 000 @VALVE 480 1.50
ALL LIFTS ARE BASED ON ZERO LASH AND THEORETICAL ROCKER ARM RATIOS
CAM TIMING OPENS CLOSES ADV DURATION
@ --- INTAKE --- --- 292 °
TAPPET LIFT EXHAUST --- --- 292 °
SPRING REQUIREMENTS
TRIPLE DUAL OUTER INNER
PART NUMBER ---
LOADS: CLOSED --- LBS @ --- OR ---
OPEN --- LBS @ ---
RECOMMENDED RPMRANGE WITH MATCHING COMPONENTS
MINIMUM RPM 3000
MAXIMUM RPM 6000
VALVE FLOAT ----
CAM TIMING OPENS CLOSES MAX LIFT DURATION
@ .050 INTAKE 8.0 BTDC 42.0 ABDC 109 °ATDC 230 °
TAPPET LIFT EXHAUST 46.0 BBDC 4.0 ATDC 109 °BTDC 230 °
REMARKS:
Reply 0
Subscribe
