pre 86 350 swap
Old May 27, 2002 | 08:32 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
pre 86 350 swap
well... my 350 is finally en rout. Its a pre 86 crate for around 1300 plus 180 for doorstep delivery from a chevy dealer. Heres a link to the motor on another site.
The setup i have now is a 305 tbi. I know i need to get a flexplate for a two piece and a new intake. What about all the sensors and what not from the 305, will all of those fit onto the older 350 block and heads? I hear that in order to use the newer serpintine belt line i can just drill and tap new acc. bolt holes to get it all to bolt up. I assume there is enough material there to do this so am i correct? Anything else im missing?
Old May 27, 2002 | 09:05 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I just finished installing my new engine into my 92 today and the only things i had to do thus far was to enlongate two holes on the stock acc. brackets. I am reusing the factory serp belt setup from my 305 TPI set up. My new engine is an 80 block with a 71 TH350. All my original sensors have gone on to the older block without a problem so far.
Old May 27, 2002 | 10:59 PM
Joshua Leslie's Avatar
I couldnt get my oil pressure sender to hook up in the older block, then, when I finally rigged up an adapter to make it work,it hit the dist. I was forced to go with a seperate gauge unfortunatley.
I was able to use my stock serp. setup from my 89TBI, I just left 1 bolt out, cuz there was no hole.
Old May 28, 2002 | 11:45 AM
Car: 88 Camaro SC
Engine: SFI'd 350
anyone know if there is enough matirial to drill and tap this extra hole?
Old May 28, 2002 | 10:00 PM
Car: 88 Camaro SC
Engine: SFI'd 350
anyone?
Old May 29, 2002 | 08:01 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Should be. I've got that engine in my van, the mounting surface in the casting appears to be the same.
xkingcodex
Feb 12, 2020 07:43 PM
bellez77
Sep 5, 2015 08:39 PM
theshackle
Aug 22, 2015 06:52 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
