need to know what parts i need
Old Jun 2, 2002 | 12:13 AM
i8urrice's Avatar
ok, here goes...i've decided to switch to a carburetor on my 305 TPI.....i need to know what parts i need to buy.......FYI, i intend to keep my electric fuel pump.......and probably need a little wiring advice too...radiator fans for example which are computer controlled......i've become very tired of computer problems on this thing.....time to go back to the basics
Old Jun 2, 2002 | 07:04 PM
i8urrice's Avatar
anyone?
Old Jun 3, 2002 | 03:37 PM
johndo1707's Avatar
i'd stick with the tpi on the 305 if it were me. its gonna be expensive but if you sell all your tpi stuf, theres a few hundred bucks you didnt have before. its up to you, but as far as parts, i've never delt with a carb swap before. sorry, someone help him out please....
Old Jun 3, 2002 | 04:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Carb.
Fuel pressure regulator, or mechanical fuel pump (and push rod for mechanical pump).
Air cleaner.
Intake manifold & gaskets.
Distibutor (non-CC, also called vacuum/mechanical advance), cap, rotor, coil, and probably spark plug wires.
Thermostat housing.
Upper radiator hose.
Misc. wires, splices, terminals, & tape to hook up distributor power and choke.
Misc. tubing & fittings to hook up fuel regulator/mechanical fuel pump, PCV valve, & heater. And bypass the in-tank fuel pump if you go with a mechanical and drop the fuel tank to remove the in-tank pump.
Torque converter lock-up switch (if auto tranny).
A slush fund to bribe emissions testing station.
Old Jun 3, 2002 | 07:37 PM
Guest
Guest
Posts: n/a
Just use an aftermarket adjustable fan switch to control the fans. The speedometer and torque converter youre on your own.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
