Found a 355 but need advice....
Old Jun 11, 2002 | 08:11 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Well atleast I think I did. Tell me what u guys think
'69 4-bolt 010 high nickel block (2-pc rear main, ARP main bolts)
-block was tanked, decked, bored .030"
10/10 cast crank
3/8" bolt Truck rods, ARP bolts
TRW flat top forged pistons, 9.82:1 compression
Moly total seal rings
Clevite77 bearings
Moroso 7 quart oil pan and pickup
Melling standard volume oil pump
Crane Energizer hydraulic cam and lifters
-284 advertised duration
-228* duration @ .050"
-.480" lift with 1.5:1 rockers
-112 LSA
-installed straight up
Cloyes true double roller timing chain
Cast aluminum timing cover
Sportsman II heads, 64cc chambers, 2.02/1.60 stainless valves, springs can handle up to .550" lift
1.5:1 aluminum roller rockers
Comp Cams magnum pushrods
Victor Jr. Intake
750 4160 Holley w/secondary metering block conversion and quick change secondary spring housing
Summit Racing distributor, 50,000 volt coil
Full accessories(water pump, alternator, PS pump, starter, brackets, belts)
Now what should I ask for this engine? He is a friend from where I Live and he told me to make him an offer. Any other questions I should ask him? He said it has 6000 trouble free miles on it and all I need is some headers and a battery and I am ready to go.
Old Jun 11, 2002 | 08:31 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
BTW: It has 6000 miles and it was his daily driver. No problems
Old Jun 14, 2002 | 08:37 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Same block/pistons/heads as me..
Prolly like $1500.00 if compression and stuff is still good.
figure it prolly cost him like, $3,000.00
if its non-roller.. More if it is.
-- Joe
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Billy Decker
Sep 4, 2015 03:46 PM
rudolphschenker
Sep 4, 2015 02:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
