Any Hood Clearance problems when switching to carb?
Old Jun 14, 2002 | 09:32 AM
bzznczzn's Avatar
Hey guys, I have an 87 Formula 350 and would like to know if there will be any hood clearance problems switching it over to a carb set up.
I have finally had enough of my TPI. It is one thing or another constantly going wrong. To many sensors and electronic crap for my liking.
The plan is to go with a holley 650 double pumper, performer RMP manifold and an 1inch spacer. Will this give me a hood clearance problem?
ANy help would be greatly apreciated
Old Jun 14, 2002 | 09:44 AM
Diablo3Z28's Avatar
Car: 1986 Camaro Z28
Engine: Built Vortec 350
Transmission: 700 R4
Well I'm not sure about your FOrmula but with my 86 Camaro hood clearance wasn't that big of an issue. I'm running a Street Avenger 670, Performer Intake with a 1 inch adapter. On top of that a K&N Triangular Cleaner. It did leave a small indentation on the underside of my hood with all that. Nothing that is visible though
Old Jun 14, 2002 | 09:47 AM
ATOMonkey's Avatar
Won't fit. Check my sig. Maybe if you used a really tiny air cleaner.
Old Jun 14, 2002 | 11:34 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
with my setup I believe it will just barely fit under a stock hood. Add a 1" spacer and I doubt it.
Old Jun 14, 2002 | 11:35 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
It will fit with the right air cleaner assembly.
You won't get much over all benefit with a 1" spacer on the
performer rpm so leave it out.
Search my posts for pics and info on how to do this.
Keyword: L-88
F-BIRD'88
Old Jun 14, 2002 | 11:44 AM
ATOMonkey's Avatar
I needed a 3/4" spacer for my fuel lines to clear the heater hose. Might not be a problem for you though.
Old Jun 18, 2002 | 01:10 PM
89Irocz23's Avatar
Yea with the rpm your going to have little to no clearance. There is no way you can use a spacer unless you have a different hood or air cleaner. I would use the spacer IMO
MustangBeater20
Oct 29, 2022 09:20 PM
Infested
May 22, 2018 11:56 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
86IROC112
Aug 17, 2015 02:00 PM
