305 to 350 swap...please help
Old Jun 14, 2002 | 12:24 PM
dheck's Avatar
I have an 83 Z28 with a stock 305 and I just picked up a pre 86 350. My questions are... will the 350 go in without making any engine compartment modifications? Will everything bolt up the same? Is the exterior of the 305 and the 350 block the same? Should the 350 go in the same way the 305 came out?
Old Jun 14, 2002 | 12:41 PM
Guest
Guest
Posts: n/a
The 305 and 350 are identical externally. You'll have no problems with the block.
Old Jun 14, 2002 | 06:56 PM
RODS92Z's Avatar
Is it cross fire injection? And are you keeping it or going to carb? There might be a hood clearance issue with a carb. Not really sure tho.
Old Jun 14, 2002 | 08:28 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yeah everythign is the same, if you swap intakes you'll need to fab the alternator bracket. (if you go with an aftermarket intake + carb that is).
I'm building another LG4 to replace the one I grenaded in my Z28.. I've got a ton of those LG4 blocks in my shop. Noone wants 'em, but its soo easy to make 'em run faster than a stock L98..
-- Joe
Old Jun 16, 2002 | 08:48 PM
dheck's Avatar
thank you for the reply. Now the hard part is getting the money to rebuild!!!!
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
