Switching LG4 to L69
Old Jun 25, 2002 | 11:30 PM
caleb's Avatar
Car: 89' Iroc
The LG4 in my Berlinetta is dying, I want to get it ready to sell, but I dont want to sell it with the dead engine, I have the complete L69 from my 85' ROC, my question is, can I pull the LG4 then put the intake and the carb onto the L69 and drop that in, and have it work with no problems?
Old Jun 26, 2002 | 07:54 AM
ATOMonkey's Avatar
Why do that instead of replacing the whole engine? There is no outward physical difference between the L69 and LG4. Unless there is some fuel injection stuff going on here it should just drop right in and bolt up.
Old Jun 26, 2002 | 11:59 AM
caleb's Avatar
Car: 89' Iroc
well, i want to keep the TPI set up so that i can put it into a different car, but I also want the berlinetta to have a good running engine before I sell it, otherwise the L69 block will just rot away because I will never use it.
Old Jun 26, 2002 | 01:26 PM
Momar's Avatar
I think you are referring to a lb9. The l69 is the higher performance carbed motor and the lb9 is the tpi.
Ben
Old Jun 26, 2002 | 01:46 PM
ATOMonkey's Avatar
OK then
Do what you're doing.
Old Jun 26, 2002 | 03:37 PM
Frank 84 Bird's Avatar
Car: 87 Trans Am
Transmission: TKO 600
It should work with no problems.
Veaceonee
Sep 29, 2016 08:15 PM
Night rider327
Oct 13, 2015 01:47 AM
RacerM
Sep 28, 2015 04:25 PM
tglennon11
Sep 23, 2015 05:30 PM
Randomtask2
Sep 10, 2015 08:37 AM
