lt1 swap hard?
Old Jun 27, 2002 | 06:16 PM
chevy power's Avatar
lt1 swap hard?
i was think'n of pick'n up a low mileage lt1 n drop'n it in my 91', but i don't know much about this swap really, i have a WC t-5 trans, i'm not think'n it'll hold up to a lt1, i would think after some mods it'll have too much power for the t-5. but i need to know if this swap is hard and if i need to swap out the trans. also does it even bolt right in or do u need to mod the engine bay? anyone who has done the swap please reply!
Old Jun 28, 2002 | 12:27 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
The swap isn't that hard. It is time consuming however.
There are several guys who are running t5s behind lt1s. I wouldn't be running any stick tires though. Eventually they will reach the duribality limit of a t5. If you are planning on keeping your ac you will have to notch the crossmember to fit the lt1 compressor on. If you don't care about ac use a 1le deleat pulley and the motor drops right in.
Hope this helps.
Kory
Old Jul 8, 2002 | 09:28 AM
Four12'sCamaro's Avatar
Hey Kory.............. What do you mean by notch the crossmember?
Old Jul 8, 2002 | 04:17 PM
Ted J's Avatar
What if he got an LT1 out of a C4 type Corvette? Will he still have issue with the A/C then? (just curious)
Ted
Old Jul 8, 2002 | 04:59 PM
ratedrookie's Avatar
Check out this web page for all the info:
http://www.hpsalvage.com/3rdGen.htm
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
