Post Swap Questions
Old Jul 12, 2002 | 05:33 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Post Swap Questions
Just a few post 305->350 swap questions:
1)Shift points-even if the shifter is in first, the tranny shifts from first to second just above 5200 rpm. I want to stay in first until 6000. Can this be adjusted? If so, is it hard (expensive) to have adjusted?
2)Cooling-The 350 runs significantly hotter than the 305. Is this due to the fan's inability to cool the rad fast enough? If I hooked it up so the fan was always running would this be enough to keep it cool.
3)Headers - It seems like the headers give off a lot of heat into the car when the vents are open. Is this a normal characteristic of headers. It is almost unbearably hot in the car, even at night.
Any help is appriciated.
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
wruiz
Aug 13, 2015 09:07 PM
reiderz iroc
Aug 13, 2015 04:57 PM
