starter, and flywheel question
Old Jul 13, 2002 | 09:15 PM
stevver84Z's Avatar
Car: 1990 Iroc Hardtop
i am in the process of swapping a 350 in where my lg4 305 is, and i have heard from many that say i need to reuse the 305 flywheel..... heres the question. i bought a mini starter for the 350 block (which has the staggered bolt pattern) they guy said it was for the 350 flywheel. will this starter work or what?
Old Jul 15, 2002 | 04:54 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
What year is your new 350? If it has a 1 piece rear main seal, you WILL need a new flywheel. But if it has a two piece, you should find out if it is a 153 tooth or 168 tooth cause I'm not sure which one the F-bodys got in 84. The 153 is just about 13 inches and the 168 is just over 14 inches if I remember correctly so you don't have to go counting teeth. Once you find out which one you have, just make sure the starter is for the one that you have, that is if you're putting a 2 piece rear main seal motor back in.
Old Jul 15, 2002 | 09:09 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You should be looking for a 153-tooth flywheel for a 3rd gen.
Saying a starter is for a "350 flywheel" means next to nothing, since there were a bunch of combinations out there. What you need to know are what mount bolt pattern and size flywheel it's for.
Old Jul 15, 2002 | 01:56 PM
stevver84Z's Avatar
i believe its for the bigger flywheel.....
Old Jul 15, 2002 | 06:09 PM
stevver84Z's Avatar
okay here we go, the flywheel i have is the larger one it measure about 14 and a quarter inches..... i have a mini race starter but thats for the bigger one, now does anyone know if the starter thats on my 305 has the staggered bolt pattern??
Old Jul 15, 2002 | 07:40 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
yes it does.
Old Jul 15, 2002 | 10:52 PM
87RS402's Avatar
I can't speak about the auto trans cars but if you have a 5 speed there is no question about it, you have the straight pattern starter.
Caspar
Jun 19, 2016 11:19 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
Trickskier
Aug 29, 2015 01:12 PM
Cleotiz
Aug 22, 2015 01:54 PM
redmaroz
Aug 16, 2015 11:40 PM
