91rs 3.1 To 350
91rs 3.1 To 350
HOPE YOU ALL CAN HELP MY SON OUT HE IS SWAPIN A 3.1 FOR A 78 350 OUT OF A K5 BLAZER THAT HAS BEEN IN HIS 78 CAMARO HE IS A LITTLE STUBORN AND DOESN'T LISTEN TO ME MUCH YOU ALL WITH 17 YEAR OLDS MIGHT UNDERSTAND
HE HAS ALREADY DONE THE 305 TO 350 SWAP IN THE 78 BUT I TOLD HIM THIS ONE WOULDNT BE SO EASY. YOUR PAST POSTS HAVE CONVINCED HIM THAT THE STOCK 700R4 THAT HE WAS TOLD WOULD WORK WONT SO HIS IS OUT BUYING A NEW ONE OUT OF A 84 VAN RIGHT NOW
I HAVE READ SOME CONFLICTING STUFF ABOUT THE DRIVE SHAFT IT SHOULD WORK RIGHT ONLY IF HE USED THE 350 TRANS WOULD HE HAVE TO CHANGE IT ?
WILL THE HEADERS HE WAS GIVIN WHEN HE BOUGHT THE 78 350
WORK IN THE 91 THEY SAID THE WHERE FOR A CAMARO ?
GOOD INFO ON THE FUEL PUMP PROBABLE BEST TO GET A REGULATOR FOR THE IN TANK UNIT BUT WHAT DOES HE DO WITH THE MECHANICL CAN HE LEAVE IT ON OR TAKE IT OFF AND DO THEY MAKE A PLATE TO GO OVER IT?
WILL THE STOCK RADIATOR WITH A SWITCH TO TURN ON THE ELECTRIC FAN WORK?
ANYTHING ELSE YOU CAN THINK OF THAT MIGHT BE A PROBLEM ?
BY THE WAY HE IS A GOOD KID AND HAS PUT A SUMMIT CAM IN THE MOTOR ALREADY AND IT IS RUNNING REAL STRONG HOPEFULLY THE HEADERS CAN BE USED TO HELP IT OUT
THANKS
THANKS
Transmission: 4L80E/4L80E
Re: 91rs 3.1 To 350
Originally posted by ROCKNRODS
HOPE YOU ALL CAN HELP MY SON OUT HE IS SWAPIN A 3.1 FOR A 78 350 OUT OF A K5 BLAZER THAT HAS BEEN IN HIS 78 CAMARO HE IS A LITTLE STUBORN AND DOES LISTEN TO ME MUCH YOU ALL WITH 17 YEAR OLDS MIGHT UNDERSTAND
I have an '84 full size van, has 130k+ on it, we've used it to pull a 2-horse trailer for the last 6 years (50k+). No trouble to date.
Having said that, the TH700's were much better after 1988.
WILL THE HEADERS HE WAS GIVIN WHEN HE BOUGHT THE 78 350 WORK IN THE 91 THEY SAID THE WHERE FOR A CAMARO ?
BY THE WAY HE IS A GOOD KID AND HAS PUT A SUMMIT CAM IN THE MOTOR ALREADY AND IT IS RUNNING REAL STRONG HOEFULLY THE HEADERS CAN BE USED TO HELP IT OUT
Thanks for the help Five7kid.
Since the headers won't work what would you recommend as an inexpensive solution for replacement ones? I'll have to buy them for him because he's drivin my 68 gto convertible in the interim.Actualy I bought it for an incentive for him to get a scholarship to college then its his.But in the mean time i'm having fun with it!
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
since it doesnt seem like your trying to be emissions compliant, just get some used headers at a swap meet
i paid $30 for mine
i paid $30 for mine
If you're going new, the non-emissions Hedman shorties for $99 seem like a good bet. If you want, they have a $99 y-pipe to go with them.
After that, things start getting more expensive. Hooker non-emissions shorties, $141, but no y-pipe available for them. Nice headers, but everything after the collector will have to be custom (until you get it to the cat location, anyway). Long tubes are around for about $150, again custom exhaust after them, and ground clearance will probably become a problem.
The 30 dollar ones sound great but iI dont have the time .
How about flowtech at summit racing I know the will be here by the weekend they are only 85 with all the hardware ?
He planned on new dual exhaust anyways. No emissions here to worry about. I'm bringing home our cherry picker from work on friday. Hope he can have it done by sunday so I can take it back monday.
Are flowtech any good?
Image is a representation
of this part.
Actual part may vary.
Click to view image
$84.95
Overview
Material Steel
Finish Black
Maximum performance headers.
GM: 283-400 1982-91 Camaro/Firebird, 1978-87 G-body cars, shorty-style, 1 1/2 in. primary tubes, 2 1/2 in. collectors, black, headers
This set of headers is precision-engineered and leak-tested to get maximum performance and fuel economy from your engine. They're made from .049 in. cold roll, flash-controlled tubing, and feature Flowtech's mandrel-formed Power Plenum collector. All ports are precisely fitted and finished with durable, leak-proof, O-ringed port seals. In addition, they come with all mounting hardware, including bolts, nuts, and premium gaskets.
Sold as a pair.
Warranty
At Summit Racing Equipment, we do business based on a very simple idea. If you're not 100% satisfied with our products, prices, or service, we'll give you your money back--GUARANTEED! Just return any new or unused part to us within 90 days from the date it was shipped to you, and we'll refund the full purchase price. (Excludes custom-ordered parts.)
All Flowtech headers are covered by a limited lifetime warranty against product defects excluding corrosion and rust. This warranty is applicable only when a product is defective because of an error in the manufacturing process. Any type of modifications (denting, bending, heat wrap) or improper installation voids the warranty.
Page 1 of 3 Next >>
of this part.
Click to view image
$84.95
Overview
Material Steel
Finish Black
Sold as a pair.
Warranty
Page 1 of 3 Next >>
