'95 LT1 F-body electical help!
Old Jul 19, 2002 | 03:42 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Hey guys, I am in need of the wiring schematic for the '95 f-body dual electric cooling fan system. I have the PCM program from one running my LT1 and don' think I have the fans wired correctly.
A HELM (GM) manual scan or digital photo would be perfect if possible. The best diagrams are the PMC connection schematics.
Old Jul 21, 2002 | 08:57 PM
90 Z28SS's Avatar
Re: '95 LT1 F-body electical help!
Do yourself a HUGE HUGE HUGE favor and go to the Library and check out the factory service manuals for the 95 F-bodys . It is the same manuals the dealer service departments use . It was absolutely invaluble doing my LT1 swap . All the skematics and everything is in there .
FWIW - on my swap , as easy as it seemed , we could never get the pcm to control the fans . The way it was wires I dont see how it possibly couldnt have worked . Sooo , I wired a toggle switch to the fans . Not what I wanted , but it worked .
Derek
Old Jul 22, 2002 | 11:18 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Thanks, I have the PCM controlling the fans now but they seem to come on too low. I had it re-programmed but not for a 160 thermostat, maybe they threw that in?? I'm only using 2 relays, high and low but the 95 uses 3 relays, so something must be wrong.
Old Jul 22, 2002 | 11:35 AM
90 Z28SS's Avatar
Do you mean the speed of the fans are to low or they just come on too early . Who programmed the PCM . It is common to turn on the primary fan on at 160* and 2nd fan on at 170* .
Old Jul 22, 2002 | 11:56 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Come on too early WRT to temperature. The primary fan is almost always on with the coolant temp riding on the thermostat.
Agostino programmed the PCM.
gixxer92
Apr 12, 2022 12:09 AM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Nervous2
Oct 8, 2015 10:53 PM
WejaZ28
Oct 3, 2015 07:38 PM
