Changing A/C components in V8 swap?
Old Jul 21, 2002 | 11:59 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
I have an 83 SC Camaro that I am swapping from V6 to 350. Is a V6 cars a/c stuff (box, evaporater core, condenser, drier, relays, ect.)different than a V8 cars? If so what needs to be changed? I have a 305 donor car for parts. Is it necessary to change it? It looks the same on both cars.
Any help is Greatly appreciated!
Old Jul 22, 2002 | 09:39 AM
ede's Avatar
ede
should be all the same, brackets might be differant, also you may want to look into what you need to change to r134 considering the cost of r12
Old Jul 22, 2002 | 02:27 PM
Guest
Guest
Posts: n/a
I think the hoses are different, since the compressor sits farther back in the car. Might want to check that, see if what you have will work or not.
Old Jul 24, 2002 | 04:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The hoses are different (because of the shorter engine). The brackets are certainly different. The compressor, evaporator, etc., are all the same (not sure about the condensor, but I believe it is the same, too).
The system can be removed intact, without breaking any hoses, since you have a V8 version available. That's what I did (sure wish the V8 system worked - does, now, 3 years later...).
RedLeader289
May 28, 2019 01:47 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
usafirebird
Sep 29, 2015 11:58 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
