LT1 install...questions...
Old Jul 23, 2002 | 08:18 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
My friend just bought a LT1 for his 91 RS. Its complete with computer and wiring. Other than a high pressure pump is there any thing else needed? Any tips for the engine swap?
Also, he is hooking this up to a 700r4 trans. Will it just bolt up and work fine or does he need a lock up switch? Thanks
Old Jul 23, 2002 | 09:10 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I am guessing that you will get more responces in the motor swap.
Brian
Old Jul 23, 2002 | 11:39 PM
Camrs89's Avatar
Oh, my fault. CLicked on the wrond one. Moderator, if you see this can you move it?? Thanks
Old Jul 24, 2002 | 10:03 PM
89Irocz23's Avatar
yeah you'll get better responses over there, but he will also need a AC delete pulley I believe. I dont think he can run the AC with the lt1, but im not sure.
Old Jul 27, 2002 | 09:46 AM
TexasLT1's Avatar
Car: '92 RS
yes you can, I am running it right now. just have to notch the crossmember to clear the compressor. nothing a grinder and a welder cant solve.
Old Jul 29, 2002 | 12:46 PM
mat89RS's Avatar
Besides fuel pump you'll need power sterring line, resistences for the VATS, Lt1 rad is recommended, hoses, general stuff line oil and coolant.
Also something that I have notice with lot of people doing this swap is that the Water Pump will tend to fail if the engine didn't work for a long time since the gasket are drying off.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
