problems with a 400 swap in an 84 z28 305 ho car
Old Jul 25, 2002 | 12:57 AM
scruffy's Avatar
i have an 84 z28 with all orional equipment accept the fact that it has headers i bought the car for 300 dollars but the motor has a broken piston skirt or bad rist pin or something to that aftect any how i decided i want to swap to a sb400 and a tci od trany but
i want to ask some one what problems i may run into and how much of a pain in the *** it might be to put a hurst shifter in and wich is the better shift to buy i usually do play with third gens but for the price now is a good time to start :hail:
Old Jul 25, 2002 | 01:07 AM
scruffy's Avatar
me again
i figure i will have to use the comp controled q-jet and mandrel fab an exhaust i'm also thinking of using a power trax non slip locker and would like to know what you all think about them
thanx for your support on the matter
Old Jul 25, 2002 | 07:16 AM
ede's Avatar
ede
should be a pretty easy swap, i'd get rid of the ecm controls unless you have e chack and have to have them.
Old Jul 25, 2002 | 07:23 AM
ATOMonkey's Avatar
The carb will need new hangers to fatten it up. You can reuse the stock manifolds and exhaust if you want to. The Ho manifolds were bigger than normal. Everything is the same externally on SBCs. It's only 6 bolts, two trans lines, and some hoses to get the engine and tranny out as one unit, just watch the wires and make sure you have lots of lifting room.
Old Jul 25, 2002 | 08:59 PM
scruffy's Avatar
exhaust and carbs
i just did a 350 swap in a 86 for a friend but as far as exhaust goes i figured i would fabracate a system with a 3 in. cat back and mandrel a 2.5 in. into a dual inlet single out cat with cut outs at the first bends in the system as for carbs i though i would have to use it with comp control to pass emisions along with a edlebrock performer egr manifold to stay legal as far as bolt up i'm more than sure it will slide right in
what i need to know more than anything is what is the best husrt shifter to use in the 3rd gen autos and emisions issues
Old Jul 26, 2002 | 01:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There are two articles on this board by Steve Green with "Stroke in the Desert", or something like that, in the titles. He did an emissions-legal '83 'Bird 383 swap, with basically all the things you discuss.
I'd go with SLP 1-3/4" primary headers rather than the TES he used. For the rest of the system, ready-to-bolt-on parts for dual-cat are available off-the-shelf - why bother fabricating? Also, consider a GM Performance Parts intake (like the ZZ4 take-off I'm using) - it's a better part than the Performer. A Weiand EGR Action+ would be better than the Edelbrock as well, and would cost less than a new GMPP manifold.
He had Jet work over his CC q-jet, and provide a new chip for the ECM. Passed emissions with flying colors, you should, too.
Hurst used to make a console Quarter Stick, not sure they still do. The more common are B&M MegaShifter or Hammer for 3rd gen console.
For tranny, I'd suggest you get with Dana at ProBuilt (he frequents the Transmission & Drivetrain forum 1-800-776-3288). He'll custom build a performance transmission for you, made to last. Will also work with you on the converter choice.
jaridjohn
Jul 8, 2024 03:49 PM
theshackle
Mar 5, 2017 06:37 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
camaro71633
Sep 1, 2015 10:24 AM
Brcharrelson
Aug 26, 2015 07:47 PM
