350 H.o.
Old Jul 30, 2002 | 10:56 PM
jobberroll215's Avatar
Car: 87 z28
Engine: 5.0
Transmission: t5
350 H.o.
I have just bought my first car, a 87 Camaro with a 305 computer feedback carb and a 5 speed trans. I was thinking of buying a GM Performance parts H.O. 350 Camaro Conversion kit for my Camaro. But the problem is that the kit says that its emission legal with a auto trans but says nothing about a 5 speed. I live in california and want to know if I can swap the engine and still pass the smog test. Also would there be any problems with the computer that comes with the kit and the 5 speed trans. Has any one out there done this swap a little advice would help.
Thanks Guys
Old Jul 31, 2002 | 02:24 AM
Drastius's Avatar
Car: 1985 Camaro Z28
Engine: Caprice LT1
The tranny should have no effect on the engine emissions.
Old Aug 1, 2002 | 12:29 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
But, by golly, it sure does have an effect.
The "certified" part won't apply to you. If the Smog ***** really dig into it, they'll recognize that "the entire HO 350 conversion package" was not "installed exactly as described in the manual".
You should pass sniffer no problem, but the stickers that come with the kit will rat on you.
Old Aug 1, 2002 | 01:01 AM
Drastius's Avatar
Engine: Caprice LT1
my bad, I failed to account for the bureaucracy
Old Aug 1, 2002 | 11:19 PM
Car: 87 z28
Engine: 5.0
Transmission: t5
How do you guy with bigger motors deal with the smog police, also couldn't I just not install the stickers. Thanks for the help
Old Aug 2, 2002 | 10:10 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I'm using a 350 300HP crate motor from goautocenter.com in my 92 RS. I don't recommend telling them you've swapped motors, as some will want all the documentation on whether your swap is legal. If you can make it look legal, and it passes at the tailpipe, they'll never know the difference. My car came with a 305 TBI 5 Speed, and I kept it TBI, though the cam is a Crane Compucam 2030, it's a 350, with bigger injectors, a custom chip and Edelbrock TBI intake, and SLP Headers with Air Injection, it passes smog at the tailpipe for the stock 305! For the visual, all I have to do is put the stock air cleaner on it.
They key is not to tell them you've installed a bigger motor.
If the motor's new and the cam is mild, you should be able to pass at the pipe.
The computer feedback carb should be able to support the additional power of a bigger motor (within reason), so just ask them to look at it before you get it smogged and if it'll pass their visual inspection, let them pre-test it at the tailpipe.
If they say it won't pass visual, go somewhere else.
-Rich-
Old Aug 2, 2002 | 02:41 PM
jharms's Avatar
I LOVE KANSAS!!! No testing, just do whatever, whenever.... Of course if I move then I might have some problems.
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
