Pic Needed-How do you connect...
Old Aug 2, 2002 | 05:54 AM
83z28-350's Avatar
I almost done finishing a motor swap that someone else started. But I can't figure out how to connect the torque arm, (I think thats what it is called-The long piece of metal that connects the tranny to the diff), to the tranny. I f someone can help me out here, it would be great! I was expecting to already have this done but I've had to go around and fix things that should have never been done. Like no clamps on the fuel lines, cut lower tranny cooler lines, multiple wires cut by previous owners, etc. Exhaust and ignition is going to finish it up.
Nick
'88 Monte SS
'83 Camaro Z28
Old Aug 2, 2002 | 08:41 AM
ede's Avatar
ede
there is or should be a small bracket with a rubber mount the torque arms mounts to on the forward end. it's on the left rear of the trans. is the trans original for your car? if you ahev a th350 buy a b&m pn 30299 kit and you'll be all set. if you have a trans other than a th350 or one originally in your car you'd have to get an aftermarket torque arm to mount it on the floor pan.
Old Aug 2, 2002 | 04:19 PM
83z28-350's Avatar
It does have the original 700 in it. I think the mount is still there but does it just rest there or is it bolted?
Nick
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TexasFormula
Sep 30, 2015 06:36 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
