Just bought a 327
Old Aug 3, 2002 | 04:15 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Just bought a 327
I just got a 327 to replace my 305 as soon as I get the performace parts for it. It's a 1968 327 with the larger crank journals in it. I don't know a lot about it yet, but will do a little research as soon as I get the block and heads cleaned up a little.
I would like to know what cam I should run in this. I have been told that a hydraulic flat tappet cam from Comp Cam's Extreme Energy cam. I would like to know what you guys think about this. And what specs I should get the cam with.
Thanks for any help you can give me.
Old Aug 3, 2002 | 04:33 PM
Guest
Guest
Posts: n/a
TBI...
Try to keep the duration down (less than 220, like 214-218 intake), run as much lift as you can, and 112 or 114LSA. Your computer will thank you. I know I'm being vague, but I'll leave the final choice up to you.
Old Aug 3, 2002 | 07:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
By 1968, 327's were low-performance, slight upgrade V8's typically with 2bbls, mostly in large sedans and trucks. The heads were better anchors than performance parts. Your best bet would be to get something better to put on top of that block.
Old Aug 3, 2002 | 07:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's right, ditch the heads, they are crap if they're the original... and they probably don't have accessory bolt holes anyway, so you won't be able to have little details like an alternator, PS, A/C.
you could stick your 305's crank in it, i.e. stroke it, and build it as a 350 instead. cubes are your friend.
Old Aug 3, 2002 | 07:49 PM
iroc22's Avatar
He didnt post it here, but he said he's going with Vortec castings.
Old Aug 6, 2002 | 12:01 AM
TZFBird's Avatar
Engine: 327
I don't think the 305 crank would work in it anyway. I think it is a large journal crank that was availible in 68. I'm not sure. Either that, or it was when they upgraded to a large journal. I'm not sure. I am going to try to find the number on the block. It's so covered in goo that it might be a while.
Also, the add says it comes with a 4 barrel intake. I didn't get the intake when I picked up the motor, so I am going back to get it later this week. Not sure if it's the stock intake, but if it is, oh well. I have to get a Vortec intake anyway.
Old Aug 6, 2002 | 07:29 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
the 305 crank is the same journal diameter as the large journal 327. it will work in that block and will raise the stroke from 3.25" to 3.48", and turn it into a 350. you'll have to have it balanced; but of course you were going to do that anyway.
Old Aug 6, 2002 | 09:07 AM
five7kid's Avatar
Save yourself some trouble - Let them throw the manifold away...
GTAman
Jul 3, 2024 07:29 PM
New2Chevy
Sep 28, 2015 12:35 AM
masonta
Sep 1, 2015 06:40 PM
pimprs
Aug 24, 2015 11:20 PM
johanlindgren
Aug 16, 2015 12:16 AM
