will this cam work ok???
Old Aug 22, 2002 | 07:02 PM
88355's Avatar
Car: 88 I-ROC
Engine: 355 TPI
Transmission: BW T5
hello all..i have a 355 TPI in my 89 ROC which is running with the stock 305 ECM (was a 305 tpi ) I am looking at this cam..wonder if it will work ok..the power band is good..but need some input..maybe some suggestions on what can be done to use it more effectively.specs are as follows
Lunati #50178 112' Sep DUR @ 50 206.0 215.0
gross duration is 258.0 268.0
lift @ 50 469.0 486.0
this cam they say is good for speed density L-98's OR 92-93 LT1
Can this cam work out for me??? 355 cid AFP-50lbs 22 lb injectors...heads are 10110810 decked .010 stock exhaust manifolds all hooked up to a B/W T5.
thanks for your time and help
Old Aug 23, 2002 | 07:29 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's a really mild cam, not too much more than the stock one, except the lobe centers are closed up a bit which will help it have better midrange at the expense of a very slightly rough idle. It should work fine.
If you want to really wake that motor up, lose the exhaust manifolds... you won't believe it's the same motor with a set of headers on it.
Old Aug 23, 2002 | 11:06 AM
88355's Avatar
Car: 88 I-ROC
Engine: 355 TPI
Transmission: BW T5
will this cam work
Thanks for getting back to me...i see that this cam will work which is awesome..You mentioned headers...what type or part number works the best..Hooker...SLP...etc.I really should replace the heads..but i just don't have that cash right now.They are off a 92 cruiser (Police) car...don't know the flow on them either,but they seem to work good---10110810 is the number on them.
PLease let me know which header i should go with
thanks again
Brent
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
masonta
Aug 31, 2015 10:14 PM
Fronzizzle
Aug 9, 2015 01:15 PM
