Will I have any problems with VATS???
Old Aug 29, 2002 | 09:16 AM
Nasty_Bird_'90's Avatar
I'm swapping an L03 for an LB9 in my bird. I need to know if I'll have any problem with the VATS. All the stuff came out of the same car so I dont think i will, i just need to know for sure. Trying to work out as many of th bugs as i can before the motor comes out of the car....you know? Thanx
Old Aug 29, 2002 | 09:45 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Welp, we would need to know what the setup came out of. Aside from that, give a brutha a shout when you do the swap, I'll run you off a prom without the vats code.
Old Aug 29, 2002 | 09:50 AM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
As long as you kept your computer from the old motor and are going to use it with the new one, you'll be fine.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
