Swap Cost thread
Old Aug 29, 2002 | 07:37 PM
LT1maro's Avatar
Swap Cost thread
ok guys, lets start this thread and post how much your engine swap costs,i see alot of people ask and i figure maby i could help the board out alittle.
Old Aug 29, 2002 | 08:14 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
used 350 shortblock with alt and PS pump $150
heads $100
flywheel $130
bellhousing/ clutch fork $50
Pressure Plate $100
Clutch $100
TPI system $350
radiator $100
headers/ y-pipe $350
motor mounts $50
ecm/prom $50
Old Aug 30, 2002 | 02:10 AM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
well mine hasn't been completed yet but here's my basic costs (not all totally accurate on prices)
350 short block, brand new -1,395
Vortec heads - 600
Vortec intake - 400?
Cam kit - 180
Balancer - 68
Flexplate - 28
2 bolt to 4 bolt - 150
Oil pan - 30?
Complete gasket kit (Throttle body, plenum, runners, intake, heads, oil pan, valve covers, etc.) - Probably around 250 to 300
Headers - 130
Holley D.I.S. - No idea on price
Radiator - anywhere from 200 to 500
22lb Injectors - 50
3" y-pipe & exhaust system (no cat) - Not sure.
Other "must be done" mods:
Headliner (rotting out) - 150
Grand total- Oh, around 3,600 bucks. Of course, exhaust and Holley D.I.S. isn't included, and that gasket set could be less and could be more.
Old Aug 30, 2002 | 08:16 AM
ROCKNRODS's Avatar
My sons swap cost was
91 camaro rs 3.1 700.00
350 from 78 k5 w/ alt & ps pump 300.00
700r4 rebuilt from 84 g van 600.00
Summit headers 79.50
custom exhaust 206.00
new radiator Auto Zone 117.00
Mallory pressure regulator :summit 74.95
B&M transpack summit 59.95
B&M 700r4 kick down kit summit 33.95
Edelbrock low profile air breather (clearance issues) 20.00
fuel pressure gage 7.00
misc (wire switches fittings clamps oil anti freeze ect)aprox 125.00
son didn't listen when i told him he couldn't bolt torque converter to fly wheel before installing trans on engine
tranny tech to make 1 good from 2 from,blown pump, 200.00
ps pump line 20.00
total cost is 2551.30 plus
he also put a timing set cam and lifters in the motor last year when it was in his 78 camaro aprox 200.00 from summit
Old Aug 30, 2002 | 12:02 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
I am predivting my LS1 swap will cost:
4000-5500 LS1/4L60E
400 Wiring Harness
500 Exhaust fabrication
800 Mount fabrication
500 A/C line fabrication
500 Misc
An expensive swap. However, those who have done it are running high 11's - low 12's on stock motors and getting around 20 MPG driving hard.
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
