Engine Mount bolts- easy removal?
Old Aug 30, 2002 | 01:48 AM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
Hey since the motor mounts in my car are getting replaced anyway, should I just cut the bolts off? I'm not messin with that A-arm crap, not unless I had a lift. I barely trust jack stands as it is.
Old Aug 30, 2002 | 01:00 PM
flyway190's Avatar
I don't see how cutting the bolts off would help you much, you'd still have to drive a nut up there to get a new bolt on. I wouldn't recommend it.
You don't have to lower the control arm to get those nuts off, all it takes is the right combination of u-joints and extensions. I'm going to assume that your engine isn't in the car since you put this in the motor swap board. It would make it easier to have another person hold a ratchet/wrench on the bolts on top so you can concentrate on the nut. The lowest one isn't very hard to get to, so you can take that nut off and one of the top ones, loosen the other one, drill out the rivets, and rotate the top shell to get the mount in. I'm not saying it's easy, but that's what worked for me. Instead of rotating it is also possible to only take the lower nut off and pry the shell up, put the mount in there, then push the shell back down and tighten it.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
3rdgenparts
Aug 8, 2015 07:09 PM
