How do you pull the pins out of the drivers side harness plug?
Old Sep 4, 2002 | 02:27 PM
john-e-boy's Avatar
I am at the end of an engine swap over (92 305 TBI to 89 TPI)and I am stuck at the wiring harness. I need to repin the plug on the drives side that connects to the firewall, I can't seem to figure out how the pins come out of the plug. If you know please help!
John
Old Sep 4, 2002 | 02:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There's a little clip on the pin that holds it in. Most harness plugs now all come out backwards. When you release the pin it will come out the front of the plug not out the back.
Old Sep 4, 2002 | 03:03 PM
john-e-boy's Avatar
So if i need to repin it I need to cut the wires and splice them back together??
Is that what I need to do??
I was trying to avoid that.
John
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
