chevy power in a beutiful pony
Old Sep 4, 2002 | 09:49 PM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
i want to put a chevy 350 in my 82 T/A. How hard will it be? ill probably have to change out the automatic transmission any suggestions on the replacement? and should i pull the computer or install one from a camaro what else will i need to change out oh i have a 305 carb in it now id like to go to Fuel Injection but can I any other things i should know or look out for?
Old Sep 4, 2002 | 10:02 PM
Guest
Guest
Posts: n/a
Uhmm... should be real easy. Your TA should have a 305 in it now, externally its the same as a 350. It'll bolt right in.
Check the carb board for info on carb tweaking. Not hard to do.
Old Sep 5, 2002 | 01:14 AM
C.M.Jones's Avatar
yes but i want a CHEVY 350. Arn't chevy 350s different than pontiac 350s?
Old Sep 5, 2002 | 02:22 AM
Guest
Guest
Posts: n/a
Its a chevy engine in the car now.
Old Sep 5, 2002 | 07:28 AM
Black84Z28's Avatar
Every Firebird from 82 up is Chevy powered.
Old Sep 5, 2002 | 07:29 AM
Dragula's Avatar
The Cehvy/Pontiac difference between engines died in the late 70's/early 80's I believe.
The third Gens all have the same engines whether they are pontiac or chevy
Old Sep 5, 2002 | 05:42 PM
C.M.Jones's Avatar
ok so a 350 will slide in will i have to do anything with the computer or should i take it out all together? whats the best fuel injection? also i want to keep the car an automatic transmission what the best for drag racing basiclly im making a street legal super sleeper 10 sec car if its possible if not i want to take off the street legal part first because this wont be a daily driver also with a 350 whats the best setup for it meaning headers and cams and others like that
jhawkeye
May 25, 2022 06:33 PM
Reborn756
Sep 4, 2015 03:42 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
sailtexas186548
Aug 24, 2015 10:11 PM
