I need some advice please.
Old Sep 17, 2002 | 07:51 PM
schwemler's Avatar
I Have a 1990 Trans Am GTA with a 305, T-tops, Koni Sport struts and shocks, Hooker Cat-back exhaust. Now I am looking to upgrade the engine.
I realize that doing up a 305 is rather pointless. I have a couple thoughts on what I would like to run but I am open to any ideas. I Had though about putting a 350 in, but since I an going to swap the motor out and do all that work I have decided to go bigger. I am thinking about a small block 400; However a 327 seems apealing as well. I would rather not go with a big block because of the weight issues, and I would like to keep some kind of EFI setup.
I am looking to get about 350hp, so I understand that before I swap my new engine in I will need subframe connectors and a strut tower brace.
Any advice anyone could give me would be very much appreciated.
Old Sep 18, 2002 | 10:30 AM
Guest
Guest
Posts: n/a
In case you didnt notice, a 327 is smaller than a 350. Theres no point in building a 327 really, unless you happen to come across one cheap and cant find a 350. You could make 350hp at the crank with a 350, but of course that would be easier with a 400. Its more a matter of if 350hp will be enough or not. If you are like anyone else around here, it wont be
If you can find a 400, do it.
Old Sep 18, 2002 | 12:48 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
There's no replacement for displacement. Go with the 400, or build a 383 if you can't find a good 400 block.
Old Sep 19, 2002 | 12:04 AM
schwemler's Avatar
Excellent! Thank you very much for your help. Now I just need to find the right intake heads and cam, but there lies most of the expenses.
Would my stock '90 305 TPI intake work untill I can afford a new one? Or what intake would you recommend?
I also read somewhere that 350 heads would be decent cheap heads for now?
And I am not even going to pretend that I know what I am talking about regarding a cam, I just have no clue waht cam is going to work best with what I am going to have. It might help if I new what I was going to do as well =); However if someone could recommend a fairly lumpy cam, that wont destroy my gas mileage I would appreciate it very much. Thanks!
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
