put a 92 305 TBI in my 89 RS now it won't turn over
Old Sep 18, 2002 | 03:50 AM
john-e-boy's Avatar
Just finished my engine swap, 92 305 TBI into an 89 RS and now the car won't even turn over. I used the wiring harness from the 92 and used the computer, had to repin the C-100 connector.
I checked all the fuses and double checked all the wiring, I even jumpered the starter to make sure it works (it does). Now I don't know where to look, Help!!
If anyone has a COMPLETE wiring diagram (not hanes) of an 89 RS and a 92 RS I would appreciate it. I am looking for one that shows where all the wires run to include all connectors, to include (the C-100) and relays ect... and locations.
Where is the starter enable relay??
if anyone has done this swap and can tell me what they did to get it running I would appreciate it?
John
Old Sep 18, 2002 | 11:14 AM
john-e-boy's Avatar
OK here is the deal for everyone that is putting a 91+ wiring harness and computer in their car...
I picked up two camaro RS's cheap I decided to swap engines in them, my 92 RS had a 305 TBI in it and my 89 had a 350 TPI in it (yes, someone else put the TPI in it). Since I am going to keep the 92 for the long run I decided to put the 350 TPI in it. So doing the swap I need both cars running in the end.
now as for the starting problem I found out what it was, There is a connector that is part of the harness that goes inside the car that doesn't go to the computer (this other connector is the C-207) well on the 89 pin M I believe is a ground for the starter enable relay and on the 92 pin M is power for the hood light. So on the 89 if you don't ground this wire you can't start the car. I left it connected and cut the connector for the hood light off and grounded the wire to a good ground. (car starts now). On the 92 if you leave the M pin connected your going to keep blowing the "ACC" fuse. I just disconnected it alltogether.
I will post everything I had to do to make both cars work properly but I am still working out some issues. When I figure them out I will post what needs to be done.
As for my current problems, in both cars I cannot get the fans to turn on when they should, I have no "High" on my heat/AC (also on both cars), and my battery gauge reads 12 volts (on both cars) with the altinator charging. I know its charging because I have been driving th 92 around for over 2weeks and if it wasn't working then the car would have died along time ago.
When I figure these problems out I will post what I did and if any one can be of assistance I would greatly appreciate it. Also if anyone has the wiring diagrams I asked for earlier I would really appreciate it.
I want to thank 91 RS (previous topics) for his help and anyone else that assisted, your posts have pulled me out of the dark on more than one occasion.
John
T
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
92purpz28
Aug 11, 2015 02:30 PM
