What do these parts do?
Old Sep 22, 2002 | 12:10 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I am wondering what these parts do.
Old Sep 22, 2002 | 04:03 AM
Boxeat2469's Avatar
The smaller part on the right is the diverter valve for the heater hose. It has a vacuum line going to it. When youturn your heat on, it allows hot water to flow to the heater core. When you turn the heat off, it allows the hot water to bypass the heater core. The other item is for the AIR tubes in the exhaust manifolds. It houses two solenoids that the computer controls. It routes air from the smog pump into the exhaust manifolds and the catalytic converter.
Old Sep 22, 2002 | 10:17 AM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I finally know, thanks alot!
Old Sep 24, 2002 | 11:29 PM
89firechicken's Avatar
get in the way and make it hard to change out plugs
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
