LT1 motor mounts
Old Oct 2, 2002 | 05:36 AM
cd90rs's Avatar
Car: 1990 Camaro RS
Engine: 96 LT1
LT1 motor mounts
People that have swapped out a LO3 for a LT1 what motor mount did you use on the passenger side? I did a search and cant find definitive answer on this. Has anyone actually used a 94 caprice mount? If so what else did you have to do? I am keeping the ac too.
Old Oct 2, 2002 | 04:52 PM
mat89RS's Avatar
The Impala motor mounts wont work. Best thing is definitely to use the corvette accessories brackets and mounts the AC on the drive side. If that's not an option for you, you'll have to make your own motor mounts using regular F-body ones and obviously notch the cross-member.
Old Oct 2, 2002 | 08:39 PM
cd90rs's Avatar
Car: 1990 Camaro RS
Engine: 96 LT1
Getting the corvette brackets will probably be out of the question. So you used regular 3rd gen mounts and notched the cross member? Or did you heat it up and pound it out of the way?
Old Oct 2, 2002 | 09:53 PM
HybridZ28's Avatar
there is allways the uses of a PA engine crossmember $$$
I take it you want to keep A/C?
Old Oct 3, 2002 | 07:56 AM
mat89RS's Avatar
Heat it up with a blow torch and notch it will a roundend hammer .
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
