assembly issues??
Old Oct 6, 2002 | 06:04 PM
nbn792's Avatar
assembly issues??
I have an older style( 2 piece rear seal) 350 block to use for an engine project. Now question 1:
How will the 2 piece main seal affect my stroker crank shaft selection?
Question 2
How will the 2 piece seal afect the t56/clutch/balance etc...???
>>>>>>Question 3
Whats it take to convert it to 1 piece seal if needed.
Sorry for the questions but the search just left me more confused. Im only asking cause i got the block cheap from family, and if i need to get a newer style block i will start junkyard hunting. Thanks everyone.
Old Oct 6, 2002 | 08:31 PM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
Answer 1:
This should affect your choices at all. There might even be more kits made for the 2 piece rear main than for the 1 piece.
Answer 3:
Check the Summit or Jegs catalog or websight. they make a nice little billet adapter to solve this problem. (you obviously won't need this if you get the crank for the 2 piece)
I don't know for sure about #2 so I'll just leave that answer to the experts.
Old Oct 7, 2002 | 07:35 AM
nbn792's Avatar
Thanks for the info jichniow, i will be sure to check my catalogues.
Old Oct 8, 2002 | 07:24 AM
nbn792's Avatar
i would like to stay 2 piece if at all possible, less to buy and greater crank selection. What will i need with a 2 piece main to use a t56. come on, i know someone has this kind of setup!
Old Oct 8, 2002 | 08:09 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
AFAIK the only way to do that is with a certain flywheel, made by Centerforce. I can't recall the part #... check their home page www.centerforce.com
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
greenyone
Sep 2, 2015 03:39 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
