do i need new injectors for a 383???
Old Oct 13, 2002 | 01:04 AM
92TPIZ28's Avatar
Car: 1992 Camaro Z28
Engine: 355
Transmission: T-5 w/centerforce dual friction plate clutch
i'm about to swap my 305 with a 383, do i need to buy new injectors, or will the stock ones work fine. the 383 isn't all high performace cause i can't afford it, so it just basically a stock 383 with a performance cam, so that's why i figured the stock injectors would work, but i'm not sure, thanks for all your help
Old Oct 13, 2002 | 07:49 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes, you will definitely need different injectors. Your current injectors feed the correct amount of fuel for a 305; the 383 will require approximately 25% more fuel at all times, since it is also ingesting about 25% more air. 24 lb/hr injectors should be just about right.
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
Keiffer76
Sep 9, 2015 08:52 PM
