Long term storage for my new 383
Old Oct 16, 2002 | 12:50 PM
LILRED383's Avatar
I had a 383 installed in my 92 RS about 8 months ago. Up until 4 months ago, I was able to run it occaisionally. I had a fuel delivery problem, so I removed the gas tank. While my tank is out, I am going to POR-15 the under carrage, and numerous rear and tranny work.
My question is this: Is there anything special I need to do to my motor, as it will probably be sitting for at least 6 more months without being started?
Old Oct 16, 2002 | 12:55 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i have heard of misting the cylinders which is is spraying some wd40 in the spark plug holes and cranking the engine acouple times to prevent rust. put a cap on the carb to keep dirt out. u might want to drain all your fluids but for 6 months i dont think it will be that bad. that is all i can think of.
Old Oct 17, 2002 | 08:42 AM
LILRED383's Avatar
Thanks for the info. I don't think my motor will be out of commission for 6 more months, I was trying to be conservative. I have a mechanical fuel pump on the block, so if worse comes to worse, I can run a line into my gas can, and run it that way.
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
TheExaminer
Sep 7, 2015 08:34 AM
