3.1 ---> 3.8 questions inside
Old Oct 21, 2002 | 11:39 PM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
was just wondering if the tranny would hold it or if i would new to upgrade that as well
working on making my thirdgen a GN
Old Oct 22, 2002 | 04:53 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
assuming you have an automatic, you NEED a new tranny
if you have a 5 speed, you can use it, but you shouldnt because of its poor strengh and for performance reasons also
Old Oct 22, 2002 | 08:32 AM
Engine: 3.1
ok and with that what kind of tranny would i need to go buy
have a automatic 700r4 right now
Old Oct 22, 2002 | 09:07 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Since the 700R4's only came with the 60* v6 or SBC V-8 bolt pattern, you will need to get a 2204_r trans to fit the 3.8 liter motor
Old Oct 22, 2002 | 12:13 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
not true, he won't have to get a new trans for that reason, I'm running a 700r4, TCI makes an adapter plate to allow a V8 700r4 to bolt to a BOP bolt pattern...
H would have to get the new trans due to it being a 60* V6 trans but if he wanted to he could stay with a 700r4
Old Oct 22, 2002 | 08:34 PM
Engine: 3.1
so your saying i can buy this adapter plate for my 700r4 and run a 3.8 off the tranny im already running
Old Oct 22, 2002 | 08:39 PM
fly89gta's Avatar
Car: 2018 Camaro SS
no, your 700r4 is for a 60* V6, you'll still have to swap trannies, swap to a regular V8 700r4...that's what i mean by saying you could stay with a 700r4...if you went with a 200-4r you'd have to swap crossmember,torque arm and the driveshaft..
Old Oct 23, 2002 | 12:55 PM
Engine: 3.1
how much does the v8 700r4 run for??
so your saying i would need to get the v8 700r4 and the plate so i could run it to the 3.8 v6
Old Oct 23, 2002 | 01:25 PM
Old Oct 24, 2002 | 10:22 AM
Snowdog 91 Formula's Avatar
The bellhousing for the 700-r4 will need to be changed. You can use your existing 700-r4.
Old Oct 24, 2002 | 01:42 PM
fly89gta's Avatar
Car: 2018 Camaro SS
even if that was true which its not(isn't the bellhousing part of the case on a 700r4?) why would u want to use a V6 700r4? Hell if even a stock V8 700r4 would be chewed up by a turbo 3.8 in no time....
Old Oct 24, 2002 | 05:37 PM
as i understand it, the internals are primarily the same
maybe somebody else can back me up on this
just for the record, the 700R4 does NOT have a removeable bellhousing
only GM trans i can recall that have removable bellhousing are the newer 4L60E's
their not a conventioal bellhousing though, the bolts to remove it from the main trans body are access from inside (well, next to the front pump after you remove the TC)
Old Oct 24, 2002 | 06:18 PM
fly89gta's Avatar
Car: 2018 Camaro SS
I thought the V6 700 had a few less clutches in the 2-3 pack, I could be wrong but I thought I read that somewhere
I do know however, that like you said,the bellhousing is one piece..
Frozer!!!
Jan 19, 2024 04:55 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
redmaroz
Aug 16, 2015 11:40 PM
