85 firebird
Old Oct 24, 2002 | 08:02 PM
pandorafowler's Avatar
Car: `91 rs
Engine: 352 TPI
Transmission: TH700 R4
85 firebird
how hard would it be to replace the 4 cyl with the 305 out of my wrecked Camaro? I already know that the struts need changing, the tranny and shaft will be coming from the camaro. would I still be able to use the 85 firebird`s rear axle with the stock 3.73 gears or would it be best to use the rearend from the camaro?
Old Oct 26, 2002 | 05:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The struts are the same, the springs are different. Motor mounts are different. But, you should be able to see what's different between the 4 cyl and donor cars and just change all that stuff out.
The 3.73 gears would be awesome, but it's probably an open rear, so "one tire fryer" and "one legged wonder" are terms you should get used to. Or, get a posi or PowerTrax unit for it.
64goatman
Sep 9, 2015 01:09 PM
jtwoods4
Sep 3, 2015 05:39 PM
Formula_88AE
Sep 3, 2015 01:47 PM
jtwoods4
Sep 3, 2015 10:19 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
