2.5L to 5.7L swap
Old Nov 2, 2002 | 12:41 PM
novafyre's Avatar
2.5L to 5.7L swap
Hey all.
I have a friend who sadly totalled his 3rd Gen Trans Am. It has a 350 engine and transmission that runs great. I'm going to buy the entire car from him, cheap, to do a swap, which I've never done before.
The way I understand, is that I will not have to spend much if I have all of the parts I need from the Trans Am, to do an engine swap on my 1984 Firebird, with a regular, slow, 2.5L engine.
Is there anything else I will need? and how long does it take to swap an engine?
Old Nov 2, 2002 | 08:01 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
well theres lots of people here thats done it, i'm sure you could perform a search and that would help.unless you want to remove the wiring harness , i would lokk into making it a carbed car/. would be allot easier to work on. on how long- that depends on you , your friends, your money and your patience.
Old Nov 2, 2002 | 08:20 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Time is the main thing you looking at.
No one can probably give you an exact time, because in every swap there is always that bolt that twists off at the wrong moment, or that part that you thought was good has crapped out on you.
I would say make sure you have a weekend clear, and an auto parts store in the area so you can get parts if you need them.
bjpotter
Jan 22, 2019 12:27 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
InfinityShade
Feb 21, 2016 01:29 PM
Thornburg
Aug 27, 2015 08:33 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
