Difference in Crank 305 vs. 350
I am planning on building a 350 for my 87 trans. It has a 305 but I want to get rid of it. I am sure there are differences in cranks just not sure what exactly they are. Thanks
Car: 4
Engine: 6
Transmission: 5
The casting is the same; but the counterweights are slightly different, to make up for the lighter rods and pistons. It is possible to make a 350 crank into a 305 one by taking off metal, not usually the other way though. Some 305 cranks (L69 for example) have X rods and therefore are balanced the same as 350 ones.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You could use the 305 crank since it's the same stroke as a 350. Con rods are all roughly the same. Since 350 pistons are larger, they'll also be a lot heavier.
Just get it all balanced and it will be fine. Even if you used a 350 crank and went with aftermarket pistons, you would still need to get it all balanced.
Engine: Many
Transmission: Quite a few
It'll run rough. Had that problem, since the cranks are so close except for balancing, accidentally put a 305 crank in a 350. Put a reground 350 crank in from the machine shop, shaking went away. If you get it balanced as an assembly however, that shouldn't be a problem. It's such a subtle difference, its hard to tell without having both cranks sitting in front of you.
1991, 305, 350, chevy, crank, cranks, crankshaft, difference, differences, engine, pistons, rods, stroke, telling, work
