Return line?
Old Nov 14, 2002 | 05:26 PM
black83z's Avatar
Return line?
WHEN (not if) i swap a 350 in place of my 305 Xfire, i will go 4bbl carb. I realize i need the mallory 3port FPR. I need to know if i allready have a return line i can hook it up to, or if i need one. If it is there, is it difficult to hook up, and if its not there, is it difficult to put in? I also realize that i will need to have different fuel lines put in to the carb. Can i use soft lines, or must i use steel tubing? Is steel tubing difficult to fabricate, or can i find it allready made (ie bolt in)? Thank you for your help.
Matt
Old Nov 20, 2002 | 07:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I resisted replying to this because I'm no crossfire expert.
But, since nobody else has...
EFI always has a return line. Fabricating a simple steel line from reg to existing return line should be easy enough.
Old Nov 23, 2002 | 05:01 PM
black83z's Avatar
I really do think five7kid is my hero. Every question i've asked on this board he has answered, nicely even. Im pretty sure youre right, because crossfire is simply two tbi throttle bodies on a really crappy and restrictive intake manifold. How would i go about checking for a return line? Thanks
Matt
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
R13_Braz
Sep 18, 2015 05:00 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
TBRays98
Sep 6, 2015 05:05 PM
