another one...v6-v8 swap
Old Nov 15, 2002 | 07:20 AM
92RSMuscle's Avatar
here it is guys, i searched for it, but i want all the info i can get...
im doing a swap from a 3.1L MPFI to a 5.7L TPI
anthing you have to offer on this will be very helpful! thanks!
Old Nov 15, 2002 | 06:16 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
heres my piece of info
have ALOT of tools
and ALOT of money
my 6 to 8 swap is costing me the following:
350 $150
bellhousing, clutch fork $50
pressure plate $100
clutch $100
flywheel $150
pistons/rings $80
gasket/bearing set $75
complete TPI setup out of a 305 $200
24 lb. injectors $200
305 heads $100
upper/lower radiator hoses $30
motor mounts $50
headers/y-pipe $200
odds and ends $200
cam $300
roller lifters $300
machine work for and valve springs $150
about $2500
and i need:
cherry picker $120
engine stand$50
air compressor$250
among other tools that i am too lazy to list right now
Old Nov 17, 2002 | 03:29 PM
MdFormula350's Avatar
have ALOT of tools
and ALOT of money
350 $150
pressure plate $100
clutch $100
flywheel $150
pistons/rings $80
305 heads $100
motor mounts $50
headers/y-pipe $200
odds and ends $200
cam $300
roller lifters $300
about $2500
and i need:
cherry picker $120
engine stand$50
air compressor$250
i agree on the price just depends on what kinda deals you can find.. roughly about 2000 to 3000 grand for that kinda engine swap..
Old Nov 18, 2002 | 04:25 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
about what I spent on my swap also...and that was buying junkyard parts!!!!!
Old Nov 19, 2002 | 02:21 AM
Joshua Leslie's Avatar
hey rsguy,
check out Pep-Boys
they will let you borrow a engine puller and stand free of charge, so long as you pay for the cost of them, as deposit. You get all the $$ back after you return it.
Old Nov 20, 2002 | 11:30 AM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
Just a quick question, 1991tealRSt-topGuy, why are you spending $600 on a cam and lifters, and then using a $100 set of 305 heads?
Old Nov 21, 2002 | 04:59 AM
Engine: 406
here comes the 305 heads can be made to outflow vortecs story.............https://www.thirdgen.org/techbb2/sho...hreadid=117410
Old Nov 21, 2002 | 04:23 PM
heh, i knew this was going to pop up
i may port/ polish the heads as described in the link above, or when $$$ allows, AFR's baby!
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
