Desktop Dyno Results - Chart Within
Old Nov 16, 2002 | 11:38 PM
92RSMuscle's Avatar
here are my results from the desktop dyno on the new 350 carb im building
i think 430 hp total
Old Nov 17, 2002 | 12:39 PM
vwdave's Avatar
I dont think DD is very accurate. I did a copy of my 305 and it said I should be putting out 250hp. On a 305 with headers and exhaust.
Old Nov 18, 2002 | 12:04 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
the program gives good ball park figures, however, when i try to input the data from my cam (very radical grind) the DD wont allow me to use the values i put in, when i change the IVC and EVC degrees it would automatically change other numbers regardless of what i did, so in some cases it just wont work
Old Nov 18, 2002 | 12:16 PM
nightrida's Avatar
to get a more realistic on the cam use .050 not seat to seat. and get the info for the ivo,evo etc... from comp cams web site. that will give you the actual cam. the goto tools and double check the lobe centerline.
Old Nov 18, 2002 | 12:22 PM
Car: '91 Camaro RS
thats what i did dude, right off the cam card itself.....the program logic must disagree with the values for this cam......i did use the .050 values, which i also got off the cam card
Old Nov 18, 2002 | 12:45 PM
nightrida's Avatar
that is strange think it did the same thing when i was trying to figure out my comp nitrous cam. the degrees was off when i entered the stats. best of luck
also try the dart iron eagle 200cc heads i think they out flow the 220 until .500 lift if i am not mistaken.
Old Nov 18, 2002 | 01:36 PM
camaro_1983_383's Avatar
does anybody want to give me a copy of DD2000. i would like it but i always end up buying car parts instead if not, do you know where i could get it for free, i.e. kazaa. my friend looked on kazaa for it and couldnt find it.
Old Nov 18, 2002 | 02:32 PM
Car: '91 Camaro RS
nope, there isnt a cylinder head onthe market right now that will outflow the AFR's (of comparable port size) especially at low and mid lift, and even when a severely ported head that flowed better on the flowbench was tested against the AFR's (article was in CHP i think) it produced 30 more HP...this was attributed to its extremely efficient port design, and high velocities within the ports. Thats with the regular AFR's too i believe, mine are the 210cc fully cnc ported competition heads. check out the charts of heads that were flow tested in CHP including the dart iron eagles. Its on AFR's site, and i have the magazine kicking around here someplace too.....
lift AFR 210CC Dart iron eagle
.200 140 129
.300 197 182
.400 240 226
.500 271 258
Old Nov 18, 2002 | 04:46 PM
nightrida's Avatar
i was refering to your dyno that has the dart 220 not the afr's. i havent dont done much research on the afr only dart, world, trick flow. i know afr's are more expensive though. i am using iron head for the street. nice intake man.
Old Nov 18, 2002 | 09:50 PM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
camaro_1983_383:
You've got yourself some mail, a lot of mail. Anyone else want an early x-mas present?
Old Nov 18, 2002 | 11:57 PM
daverr's Avatar
dd2000
please no more desktop dyno numbers.these numbers that desktop dyno comes up with is total bs .my sugestion for motor build up is to visit a very good speed shop in your area ,they know what works and what doesnt.oh and another thing dont go by magazine articles either ,cause their totally bogus too.
dave
Old Nov 19, 2002 | 02:37 AM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
Originally posted by Dustin Mustangs
camaro_1983_383:
OH OH ME ME, I think.
Old Nov 19, 2002 | 09:08 AM
Car: I
Engine: Taunt
Dave-
The best thing any speed shop is going to be able to do for you is ESTIMATE the power of a certain combo or of an additional part. If you build two engines with the EXACT same parts and methods they won't make the exact same power, granted they might be close. DD 2000 is just another way of ESTIMATING what certain parts will do to your power curve.
Don't get me wrong, you can't and shouldn't take these numbers to the bank. The fact of the matter is though, DD 2000 is more creditable than the minimum wage register worker at NAPA. Belive it or not, actual 'automotive and computer engineers' put this program together, that's a llot more than I can say about most 'speed shops'.
I am not trying to flame anyone, I just think people expect to much from DD 2000, and then get pizzed when it doesn't produce what they want.
92Transam: I hear you knockin'!
Old Nov 19, 2002 | 06:08 PM
Car: I
Engine: Taunt
92Transam-
Sorry dude:
Message from yahoo.com.
Unable to deliver message to the following address(es).
<cardude2@hotmail.com>:
65.54.252.230 failed after I sent the message.
Remote host said: 552 Requested action not taken: exceeded size limit
Looks like your account won't accept mail of this caliber. If you really want it just open up a yahoo account and shoot the address to me, they'll allow it.
:lala:
Old Nov 19, 2002 | 06:48 PM
daverr's Avatar
speed shop
Dave-
napa= parts store not a speed shop
i dont know what speed shops your dealing with maybe u got bad experience or something.usually speed shops have alot years of building engines.the ones i deal with have at least 30-40 years in business i doubt they would steer me in the wrong direction.
dave
Old Nov 19, 2002 | 06:55 PM
92Transam's Avatar
92Transam-
Sorry dude:
:lala:
Okie here ya go Ive had this acount for awhile Jessethecarguy@yahoo.com
Old Nov 19, 2002 | 07:04 PM
Car: I
Engine: Taunt
You got me. Every time I send my car to any shop it gets returned to me with something else broken. I can yak your ear off on the subject, but I'll spare you the ranting.
My point is that DD2000 is just for estimating the characteristics of different combos, ones that maybe you (or your speed shop) haven't already had the experince of running. I don't know about you but I am not about just copying something that I've seen or run before, that's just too easy.
DD 2000's a toy not a tool, but that doesn't make it a bad thing.
Old Nov 19, 2002 | 07:12 PM
Car: I
Engine: Taunt
92Transam, I think that did it, Check your mail.
Old Nov 19, 2002 | 07:36 PM
92Transam's Avatar
Old Nov 19, 2002 | 08:58 PM
Guest
Guest
Posts: n/a
If you guys are going to pirate software, please dont use the board to do it.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
