How much horsepower would i pick up from converting my tbi to tpi? If i did this would i have to change anything else in my car like the exhaust? My car is almost completly stock w/ a k & N filter, hypertech chip, high performance spark plugs and wires.
I have a small rivalry with a friend with TPI, we run almost identical setups save for a few parts,
16 inch IROC-Z rims vs 17 inch vette rims
Steel vs aluminum driveshaft
2.5 inch free flow cat + cat back and flowmaster vs his 3 inch
1.6 rocker arms vs 1.5 rocker arms
He can run a best of 15.1 while I run a 15.4...
We ran on a dyno prior to my 1.6 rocker arms mod and he had 280 ft/lb vs my 258 ft/lb of torque and he pulled a 180 HP and I had 158 HP.
I'm pretty sure the rocker arms made a serious improvement on my part, probably running around 270 ft/lb of torque at the rear wheels now.
I dunno if 3 tenths is worth the whole tpi change for you... the worst part being the fuel pump change and I've done one already... not a fun job.
What arew the other constants? Are you running the same heads as your friend? What about cams or gears? I am not doughting ya just curious.
in factory trim tpi has a few very noticable things over tbi. 1. cam, 2. heads, 3. more developed intake system.
for the several hundred dollars of a change over there is a lto you can do to tbi to more than make up the difference. also, when it comes time to go beyond stock tpi parts, they are expensive.
later
tim
later
tim
