Tbi To Carberated ?? Help!!
Old Dec 28, 2002 | 06:37 PM
Xceleratemaro's Avatar
here is the situation i am swaping out a motor in a 90 rs camaro
it already has hedder and true dule exaust
he just bought a 383 4 it and a preformer intake with a holly carb(not a dubble pumper)
we will run new fuel lines and a side mounted fule pump on block
here inlies the problem the electric fuel pump is in the fuel tank now and we need to sitch it out so the block mounted pump will work but how??
or would it be easer to buy a fuel tank out of a caberated car and switch them over? if so are all 3rd gen tanks the same?
thanks for you replies chris
Old Dec 28, 2002 | 10:08 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
There's an article under "Technical Articles" section that's on the homepage of this really cool website ---> www.thirdgen.org
Just look under "Swapping from EFI to a Carb in a Thirdgen" under the "Carbs/F.I." section.
Or you can just --->Click Here<---
Old Dec 28, 2002 | 11:49 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
just buy a 3 port AFPR
Old Dec 31, 2002 | 04:28 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
[i]Or you can just --->Click Here<--- [/B]
In that article, it says that switching to a carb will make it so the torque convert will not lock up. Is this true?
Old Dec 31, 2002 | 04:58 PM
AJ_92RS's Avatar
That's true, but all you need is this (or something similar) .....
Click on pic
It only locks up the TQ in 4th gear, but it's better than nothing.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
