question~please read
Old Jan 2, 2003 | 01:05 PM
ss1969's Avatar
hello~
i dropped a new caprice 350 crate motor inmy 86 tpi (305) iroc~im allmost done, but i have run across a couple minor problems:
1) my new tpi intake manifold only has 2 holes in front ~ my 86 tpi manifold has 3. i have no hole for the water temp sensor~~should i tap a third hole for it or is there a alternate location for this temp sensr (like in the head)
2)new motor has a hole in oil pan for a low oil sensor~does anyone know what size (thread pitch etc.) plug to use?
so far thats about it ~ thanks
Old Jan 2, 2003 | 01:39 PM
vwdave's Avatar
Does the crate motor have centerbolt valve covers? I am just wondering.
Old Jan 2, 2003 | 01:49 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
The hole in question in the intake is for the sensor for the 9th injector (cold start injector). If you are not in a cold area you can get rid of the 9th injector cause you don't need it. If you're in a wintery place then you will have to fix something up. As for the oil pan I am not sure. The small sensor is the cold temp sensor the big one is not needed if in a warm climate.
Ghettobird52
Jul 5, 2024 11:18 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
reiderz iroc
Aug 13, 2015 04:57 PM
