95 LT1 w/4L60E question
Old Jan 6, 2003 | 12:38 AM
sinner's Avatar
Car: 1992 Camaro Z28
Engine: 1995 Camaro LT1
my swap is getting close, i am lookn at trannys. i found a 94 4L60E for a good price but i have all 95 technology. ive been told only a 95 will work with my 95 stuff. what do i need to do to the 94 tranny to make it work?
Old Jan 6, 2003 | 12:27 PM
mat89RS's Avatar
it's exactly the same.
Old Jan 6, 2003 | 02:20 PM
sinner's Avatar
thats not what pro built transmissions said on my post in the tranny section. now im really confused
Old Jan 6, 2003 | 04:52 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
94 and 95 should be the same. 93 is different in both fuel injection and transmission.
Old Jan 6, 2003 | 08:36 PM
sinner's Avatar
i talked to a pretty reliable source today and ill give you the gist of what he said:
the 94 has a few differences, the first being technology
the 94 has a different plug, and is obd 1
the 95 is obd 2
the 94 has small problems with locking in 1st when put under pressure like spinning tires on wet pavement, which you have to get out of by turning off the key then back on
i guess the 95 cleared that stuff up
i guess the 94 also has a leakage problem where the electronics come out of the tranny that they cleared up also
so, thats what i was told:lala:
Old Jan 6, 2003 | 10:15 PM
TexasLT1's Avatar
Car: '92 RS
'95 is most DEFINITELY OBD1, it only has an OBD2 ALDL connector. Everything else about it is OBD1. Anyone who tells you differently is only very slightly correct, GM switched to OBD2 at the VERY end of '95.
Old Jan 6, 2003 | 10:41 PM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Here this should clear some stuff up for you.
http://web.camaross.com/forums/showt...0&referrerid=0
Old Jan 7, 2003 | 09:53 PM
sinner's Avatar
well he gave me so much info in such a short conversation i may have gotten it confused
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
87iroctheo
Dec 4, 2016 11:47 AM
midge54
Aug 29, 2015 09:51 PM
redmaroz
Aug 16, 2015 11:40 PM
