Merlin BBC oval ports..
Old Jan 11, 2003 | 09:19 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Im looking for a used pair($600 with valves and springs)but I need to know if its the 265cfm or the 290 cfm port volume version..Is this a good deal?And what kind of camshaft would you recommend for a cam..Its a steel shimmed gasket 8.5 compression ratio 454 with cast pistons
Daz
Old Jan 11, 2003 | 11:10 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Flow numbers I don't have but the intake runner volume of the oval ports are 269cc but there's lots of metal in the heads to open them up a lot more. They can be ported enough to outflow factory 990 rectangular port castings.
Cam choice is up to you but the springs are set up for a maximum of .570" lift. That's just above mild for a BBC. Mine have been redone for a max of .650" lift. New springs, locks, retainers. Machined down the valve guide and positive lock seals.
That compression is very low. A comp cams Xtreme Energy XE274H-10 would probably work well.
redformula88
Oct 14, 2015 06:08 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
vortec tpi
Sep 26, 2015 08:14 AM
vortec tpi
Pacific Northwest Region
Sep 26, 2015 08:13 AM
hdis2002
Sep 8, 2015 02:52 PM
