tp1 vs lt1
Old Jan 18, 2003 | 12:01 PM
ShadowZ28's Avatar
Car: 91 Camaro RS
Engine: L03 for now......
Transmission: 700R4 for now.......
tp1 vs lt1
i was wondering what intake system i should use. ive been debating on whether to do a tpi setup or lt1 intake. id really just like to know the advantages of each, if possible. thanks guys
Shadow
Old Jan 18, 2003 | 12:34 PM
TexasLT1's Avatar
Car: '92 RS
if you can easily get an LT1 intake, dont even waste your time with the TPI. Everyone knows that the TPI system cant adequately feed an engine past around 5000 rpm, and especially not a moderately modified one. If you are just going for a stock engine, TPI may be fine, but if you plan on doing really any mods at all, go with the LT1 intake. Only thing you will have to do is get it drilled for a regular distributor.
Old Jan 18, 2003 | 02:28 PM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...ght=lt1+intake
Old Jan 18, 2003 | 02:35 PM
ShadowZ28's Avatar
Car: 91 Camaro RS
would you take the super ram intake over the lt1?
Shadow
Old Jan 19, 2003 | 03:00 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
No the super ram is nice but costs alot more(1000 or more last I checked) you can buy an lt1 intake for 100 dollars can probably get it running on the car for less than 500. that is alot cheaper than a aftermarket tpi intake which will make alot less power.
Kory
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
