69 pontiac 350
Old Jan 19, 2003 | 01:59 PM
1991 RS 305's Avatar
69 pontiac 350
HELP, is this a good buy?
I came across a 350 out a a 69 Pontiac for $75. The cylinder walls are very smooth. I did notice a ridge about a quarter inch from the top of each cylinder, probably from the rings (right/wrong).
No heads, no pan, just rotating assembly. It turned very smooth with a wrench on the crank if that's any help. Pistons looked healthy, no marks on them.
Any disadvantage going with the GEN I block besides the rear main seal?
I was planning on throwing some new parts (heads, cam, intake)on the trusty 305, but now I have come across this 350 and am rethinking what I should do.
Thanks for any input in advance!
Old Jan 19, 2003 | 05:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
So, is it a Pontiac 350, or a Chevrolet 350??
If it's a Pontiac one, it's totally, altogether different in every way from a Chevrolet one, and won't interchange any parts whatsoever with your 305.
You can easily identify the 2 motors. A Pontiac motor has a big aluminum timing cover that fits all over the front of the motor, including the water pump discharge passages; but a Chevy motor's water pump passages are outside the timing cover flange. Also, a Pontiac block has a curved surface across the top in between the 2 cyl head decks; but a Chevy block is straight there.
Old Jan 19, 2003 | 07:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If its a Pontiac 350, don't bother using it in your car. It does not have a good bore+stroke combination like a Chevy 350. The Pontiac 350 has an awfully small bore and a really long stroke, so its like a 305 sbc with athsma (spelling?). it something like a 3.75" bore and a 3.7" stroke (don't know exact numbers, but something like that) so it breathes alot WORSE than even a 305 Chevy does.
Old Jan 19, 2003 | 09:26 PM
Well I guess I'll pass on this one, Thanks for the input!!
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
angel2794
Sep 8, 2015 06:22 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
Eric-86sc
Aug 24, 2015 09:01 PM
