LT1 cam that will work with a 96 computer?
Old Jan 21, 2003 | 09:23 PM
LT1swapper's Avatar
Since I have my 96 LT1 partly apart to clean it up, I was thinking about putting a bigger cam in. Anyone know of a good grind that won't require a re-program on the OBDII computer? I am going to be running 1.75" SLP headers with dual cats, 3.45 rear, and a Tremec. This is going in my 89 Formula.
Old Jan 22, 2003 | 08:40 AM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
I can tell you that when I put the LT4 HOT cam in my 96 WS6, it would set the light everyday. Random misfire codes constantly.
I don't think any cam other than stock will not code. But you can get a 95 computer and work just fine. All you have to do is change the knock sensor resistence. I ended up going with a '95 computer in mine as that was the only way back then. Now you can get them programmed or do it yourself with LT1 Edit.
Old Jan 22, 2003 | 09:13 PM
TexasLT1's Avatar
Car: '92 RS
Dump OBD2, in my opinion its worthless. Like TTA said find a '95 computer and you can very easily tune for ANY mod you can think of.
Old Jan 22, 2003 | 09:43 PM
LT1swapper's Avatar
I ended up ordering a harness and computer from Howell today. They talked me into switching to the 95 computer. Its a little more money this way but I think I will be better off long term.
Old Jan 22, 2003 | 11:04 PM
z86roc28's Avatar
How much did you get the harness and computer for? And what is LT1 edit?
Old Jan 23, 2003 | 09:03 AM
TTA 1387's Avatar
LT1 Edit allows you to program the computer. Here's the website:
http://www.carputing.com/
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Thirim
Aug 9, 2015 06:19 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
