Thinking of bigger cam look within.
Old Jan 25, 2003 | 12:22 PM
NOSFEDGTA's Avatar
I am currently running a comp cam with 224-230 dur @50 - 535-545 lift with 1.6 rockers. I am thinking of going to a a 242-248 dur @50 with 570-592 lift using my 1.6 rockers. My question is will I see a much bigger power gainor will I hurt power. I have seen many times wre people do a cam swap and wind up loosing power. I just dont want that to happen.
here are the motor specs
355 10:1.1
fully balanced
afr 190s flow 267cfm
edelbrock performer rpm
holley 750 dp
full msd ignition
full roller motor
cam listed above
shortie headers
3in exhaust
2800 stall
ford 9in with 3.70s
Drew
Old Jan 25, 2003 | 01:40 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
I would guess that a 355 would need a top-notch exhuast system using true dual 3" pipes to take advantage of the bigger cam - but no doubt others would suggest the swap or even already run a similar hot cam.
I also think that with 3.70 gears you won't be able to fully take advantage of the peak power with the hotter cam installed unless you road race.
I wouldn't do it because it would likely lose more streetability than gain useable power but one would need to road/dyno test it before and after to be sure. You may like the results.
midge54
Jan 29, 2017 07:00 PM
italiano67
Dec 11, 2016 09:21 AM
gta90
Sep 15, 2015 04:00 PM
Cameeeero
Aug 20, 2015 03:06 AM
86White_T/A305
Aug 17, 2015 12:16 AM
