s10 xtreme 350 can it be done????
Old Jan 28, 2003 | 07:11 PM
chefdan1's Avatar
my buddy has rode in my car many times and loves the rumble of a v-8. the only problem is he likes s-10 xtremes there are nothing wrong with these i like them too, my question is can a 350 motor like mine be put into a 1999-2002 xtreme?? i think that would be an ultimate ride for him b/c he loves power and trucks. also he is considering fuel injection or a carb?? he's not sure which to go with
thank you all.
Old Jan 28, 2003 | 07:25 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Try your question at www.s10forum.com. They also have a forum about engine swaps.
Old Jan 29, 2003 | 04:54 PM
84 Challenge's Avatar
The last Shade Tree Mechanic show I saw....they were lowering an LT1 into an Xtreme.
Brandon
Old Jan 29, 2003 | 07:05 PM
efbaudy's Avatar
i dont understand...people that are members of this site because they love f-bodies so why should we push our own people onto different sites just to ask a question about a non-f-body...people please lighten up
Old Jan 29, 2003 | 07:08 PM
efbaudy's Avatar
lol sorry i forgot to add my comment about the s10...im not familiar with the s10 engine bay...but i would imagine u could do a 350 but u would also need new transmission and rear end and also maybe modify your bay...im sayin this because i had a ranger that had a 4.0 in it and looked like there was alot of room left over but i guess u should ask someone else who knows trucks...altogether tho the process could be costly if u dont do it all yourself
Old Jan 29, 2003 | 07:42 PM
black83z's Avatar
I think that a smallblock into an S10 is a fairly common swap. Common enough that jegs sells headers made specifically for that application. I would imagine that all the typical swap considerations must be taken - ie tranny, motor mounts, fuel, etc. Just my 2c.
matt
Old Jan 29, 2003 | 08:19 PM
1982chevycamaroz28's Avatar
u should be able to swap a v8 into any s10, u gotta use some parts from corvettes , forgot which parts though. but my friend in skool finished his 406 sbc swap into his 92 s10. came out pretty sweet too.
Old Jan 29, 2003 | 09:06 PM
Momar's Avatar
Which motor does he have now? If it is the 4.3 it has the same bellhousing bolt pattern. That means that he should be able to bolt up to his existing transmission. If it is anything else he will need a new tranny.
Ben
Old Jan 29, 2003 | 09:28 PM
TBones87's Avatar
Car: 87 Camaro LT.
Engine: 305 LG4
There was an S-10 for sale down the road from me a couple weeks back. It had a 350 in it. It was the older body style, but i doubt the engine bay is much different.
Old Jan 29, 2003 | 10:28 PM
87daddyformula's Avatar
Car: Formula
Engine: 5.0L
Transmission: 700R-4
Lingenfelter makes a 427 twin turbo s-10; granted, he has tons of money behind him and unlimited resorces but if he can fit all that into an s-10 then your friend should be able to put a 350 into his...now, wether or not he has room to perform routine maintenance is a whole nother story.
Old Jan 29, 2003 | 10:35 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
actually, you'd be much better off asking at www.s10v8.com
Old Jan 29, 2003 | 11:17 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
It would be sweet to do it. Drop in a LS6 and T56 and go wipe some Lightning ***. It would handle decent also.
Old Jan 29, 2003 | 11:29 PM
Engine: V8
that and s-10's have an impressive power to weight ratio...you wouldn't think it, but my friend used to have a 92 (older body style) that tipped the scales at 2750 with him in it
Old Jan 30, 2003 | 12:34 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
since i'm assuming that your friend has a 4.3L in it now....it would be worth doing the swap i "Guess".....if he has the 4 banger, well then sell his truck since the cost would be too huge.
now how fast does he want to go? My friend has a 11.60 S10....using the 4.3L engine with some bolts ons and NO2.
Now if he wants all motor i'm hoping my truck will be the low 13s soon with the 4.3L v6 motor in my 98 S-10 SS.
On the other hand, I can give you the number of a guy I know in Indiana that turbocharges the 4.3L and will put you in the 10s on pump gas, daily driven. He owns his own shop called Power Concepts, Inc. Although it all depends on $$$$. On today's v6 vortec motors I don't see the swap being that big of a necessity any more. There is more than enough technology out there to get the newer v6s going more than quick enough. Bare in mind that the 4.3L v6 engine is a 350 motor with the back two cylinders chopped off, so everything that works on a 4.3L will also work on a 350, just 2 less parts needed. If any more info is needed for your friend on what to do to his truck, PM me.
Old Jan 30, 2003 | 10:05 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
i belive Advanced Adapters has all the adapters you need for the conversion.
i was on there looking to put a 305 in my cherokee
Old Jan 31, 2003 | 07:38 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Because that's where the information is, Einstein. And he'll get a lot better answer than your, "I'm not familiar with it but I imagine you can do it..."
Old Feb 1, 2003 | 12:28 AM
LottaBallsCamaro's Avatar
I've seen about 5 different swaps like the one your talking, its real common. I've seen one with an LT1 and 6speed done and all the others were sbc's with autos.
Old Feb 1, 2003 | 06:33 AM
Momar's Avatar
Dont know what transmission it has but there is a newer non extreem s10 in town here that has an LT1.
Ben
Old Feb 1, 2003 | 12:44 PM
Don't you know that every member here knows everthing about every car/truck?
89fast5oh
Sep 8, 2015 09:55 AM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
