water pump?
Old Jan 30, 2003 | 11:38 PM
Kandied91z's Avatar
water pump?
i have to get a new water pump....
what is the difference between reverse rotational and the other?
i'm looking into changing to a march sbc setup; to do this they require i change my stock water pump.
i don't know enough about this subject so if anyone can shed some light i'd appreciate it!
Old Jan 31, 2003 | 12:29 AM
H0TR0Dn's Avatar
Car: 88 Formula 350
A reverse rotation pump is just that. The serp. belt runs around it backwards which in turn spins the pump backwards. Depending on how you run your belt when you get through will decide the water pump you need.
Old Jan 31, 2003 | 09:39 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
It's possible that the March setup needs a short water pump as opposed to a long (stock).
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
